shelf life at -86C
How long can one store pesticide extracts at -86C in anorganic solvent - say a quecher's matrix?
vestel b. shirley, president
betves inc
166 norwood drive
reidsville, nc 27320
Hi
A bit of a wide question considering the number of different families of pesticides, can you narrow it down abit?
To stress the stability point a bit, you can instant deep freeze a substance, but in the wrong enviroment thawing will cause breakdown spoiling any validation/accurate sampling attempt. To give an example, a few years ago I worked with substances containing a dichlorinated bensaldehyde function, just picking the wrong solvent working with +99% standards spoiled the work.
Izaak Kolthoff: “Theory guides, experiment decides.”
Hard to say. I am trying to come up with a method to sreen for pesticides to find out what i need to buy for each project.
What might be the different ways to thaw out
organophosphorus versus organochlorine versus carbamate versus triazines?
betves inc
166 norwood drive
Users browsing this forum: Google [Bot] and 1 guest
