GC Chemstation A.10.02 - password recovery?
I have just started using a newly acquired (used) HP5890 GC with ChemStation Rev A.10.02
I started the tutorials, changed from Operator to Manager level, and apparently used a password that I can't seem to recall.
This is a Windows 2000 computer.
Any ideas?
Henri
Question restated:
That is - any idea on whether (and how) a password can be reset or recovered for this system?
Henri
Try this http://www.chem.agilent.com/Library/Sup ... UVpass.pdf although it is not quite pertinent to your version / OS it may help
A friend at Agilent helped me solve the problem. I "simply" needed to delete a specific line in the win.ini file that set that access level. Of course without his help I would have never found that line!!!! "It is simple - once you know how to do it."
I hope someone can benefit from this - actually I hope no one else is dumb enough to find themselves in the situation I was in!
Henri
A friend at Agilent helped me solve the problem. I "simply" needed to delete a specific line in the win.ini file that set that access level. ...
For everyone who need this.
Search WIN.INI for line "level=" and delete this.
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 26 guests
