Chemstation data analysis menus
I'm missing the menus for data analysis in Chemistation D.03. I just have icons.
Any idea how to get the
"File", "Spectrum", "Library"...etc. tabs to view?
Thank you.
The menus are loaded from msbar.mac or gcbar.mac (in msmacros or gcmacros.) Check that they are still OK.
If the problem persist, open the configuration editor and just click through all the screens. It will re-install / repair the macros when it updates the config file at the end. I have that problem a lot with the E.02 Chemstation revision.
just reload the software
Thanks all for your suggestions.
Chip set drivers were not working in device manager. Reloaded drivers.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 6 guests
