post-column obstruction
Dear all,
I am doing LC/MS analyses using capillary LC. I use 50 um ID Peeksil tubing. Most of the time this works fine. However, I sometimes get post-column obstructions. I find it difficult to find an explanation for these post-column obstructions. I can imagine getting pre-column obstruction, for instance due to sample impurities. Is there anyone that has an explanation for this phenomenon? My system setup is the following: Mobile phase A, 5 mM ammium acetate, mobile phase B, 97.5 % acetonitrile, 2.5 % water, 5 mM ammonium actetate. I run gradients from 10%B to 100% B. The flow rate is approximately 20 ul/min (I am using a flow splitter to get these low flow rates).
I hope someone has an explanation for this so I can change my setup and prevent these sometimes annoying obstructions.
Koen
Only speculation, but ammonium acetate is a pretty fair nutrient. Any chance you have some microbial contamination *inside* the column? I have no idea how you would confirm this, though. :(
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
