Trouble Calibration Varian 450-GC w/ Galaxie
Hello Everyone,
I'm currently in quite the conundrum. You see, 4 of our 5 machines run using EZ Chrome. The method for calibrating those machines is quite easy. As for our extended analysis machine, it uses Galaxie, which is not too user friendly. If anyone could link me an in-depth walkthrough or point me in the right direction for calibrating the machine to a Level 1 Gas standard, I would be very much obliged.
Thank you.
Contact your local Bruker supplier :wink:
I've just been to the factory and found the software easier to use than EzChrom. From memory of both the steps are pretty much the same just different in appearance.
In total there are 36 users online :: 2 registered, 0 hidden and 34 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 34 guests
