Formic Acid analysis with C18 HPLC column
Can we do HPLC analysis with C18 reverse phase of formic acid in the presence of sodium bicarbonate using 10mM phosphate buffer of pH 2.0
We use a specialized organic acid column.
I analyse acetic acid with a reverse phase C18 column.
0.1% phosphoric acid, isocratic at 100% aqueous, 150 x 2.1 mm HSS T3 column (compatible with 100% aqueous conditions). Retention isnt great (k' = 1.5) but it separates from codeine which doesnt elute until a high organic flush at the end of the run.
Detection is UV absorbance at 210 nm. Sensitivity was better than i expected.
Presumably formic acid will elute faster, so good luck!
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
