LCMS Agilent report
Hi everyone!
My lab has an LCMS Agilent HPLC 1200 series and MS Agilent 6110 and we are looking for a specific report where we can find the UV chromatogram and all the specs from each peak. We develope pharma research and we use the LCMS for routine control.
The predefine reports from agilent don't give both signals. I've only found different reports. is there any way to generate both results in the same report?
Thanks a lot!
I suppose you use MassHunter?
The report function of MassHunter is absolute bullshit, but it should be possible to insert an additional chromatogram into an existing report. Our MassHunter came with written and video tutorials on customizing reports. It's still crap and you can't really finetune things as you would like to, but you should manage to do some rough customization. If not - call Agilent and tell them they shall send you a template.
Guys at Agilent are usually very heplful - but I'm not sure what their programmers did smoke before making the reporting module of MassHunter.
That's the main problem: we don't have the MassHunter. We are a small lab with a Single Quadrupol. My project coordinator doesn't want to spend lot of money with a specific report (create for an external Agilent company specifically for us) and he request me one report with all in it: specs of each peak and UV signal.
So what software are you using for data acquisition, Chemstation?
Yes!! this one... :?
Hi!!
I've made one progress: I've achieved to put one spectra of the main peak, but only this one, not for the rest.
Any idea?
grrr, I hate chemstation!!!! :cry:
Users browsing this forum: Semrush [Bot] and 10 guests
