Copy chromatogram
My question could be silly as I am new to this form and do not know if somebody already replied. I have Chemstation and don't know how to copy the chromatogram to powerpoint. Earlier I had a menu at right hand side (toggle between retention time and no retention time copy chromatogram like that). Now this menu disappeared. Can somebody tell me that how to make that menu visible? or any way to copy the chromatogram.
Thanks in advance
RS
You need to be in the Data Analysis screen
In the lower tool bar next to the 'Signals Displayed' box, you will see an icon with a capital "T" on it. Click on this and the toolbar will appear on the right of the display.
Gasman
Under Graphics in Data Analysis, last choice down is Copy chromatogram, that puts it into clipboard, where you can copy into Word, Powerpont, etc.
At least in the versions I have....and in Full Menu...
Thank you guys. Would please also let me know that how to change the scale of Y axis in final chromatogram? My blank run is linear but scale on Y acid make it zagard line because scale on Y axis becomes very fine.
Thanks for your time.
RS
Again, you must be in the Data Analysis screen.
Click on Graphics and then Signal Options. In the resulting window you will see the area 'Ranges'. Click on the 'Use Ranges' button. The boxes to the right will then be active and you can enter the Time range that you want (X axis) and the Response Range that you want (Y axis).
Gasman
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
