Internal standard for organochlorinated pesticides
Hi all,
We are analyzing organochlorinated pesticides by GC-ECD with HP5-MS column . Now I want to use some internal standards to improve the quality. What compounds would you recommend to be the istd ?
Are you using single or dual column? Which pesticides? I'm fairly certain you will find some answers on page 10 of this U.S. EPA method 8081. http://www.accustandard.com/asi/pdfs/ep ... /8081B.pdf
Hope this helps,
Ty
~Ty~
Thank you very much. I use single column.
I always say 'The more, the merrier' with internal standards. I would use both of them if you can resolve them from other analytes and the two recommended surrogates are almost a necessity for GC/ECD. Many times in my past they have helped solve chromatographic issues as well as ensuring the integrity of the results.
~Ty~
In total there are 23 users online :: 0 registered, 0 hidden and 23 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 23 guests
