Viewing sample name is Chemstation B.04.02 and sequence tabl
Hello, I have a few questions about Chemstation B.04.02
I set up a sequence in Chemstation and when I run the sequence (either partial or running the entire sequence) the Chemstatus status box only shows the vial number and I would like it to show the sample name as well. Does anybody know how to get this to display? I haven't encountered this problem with the previous version of Chemstation (B.03.02) I'm used to using.
Another question I have is how to print off the sequence table. I usually have done, File - Print Sequence - then select quantification part. WIth this version though it prints off several pages and is not very clear. What I am having to do is open up the sequence table in the offline copy then do a print screen and paste into Word then print from there and this is very annoying, any help would be appreciated!!
Qualifier - It's been awhile since I've used Chemstation, and I don't remember which version is which.
If your version does partial sequences, there should be a print button when you go into the partial sequence window. That should give you a different looking printout than printing directly from the file menu.
---Another question I have is how to print off the sequence table. I usually have done, File - Print Sequence - then select quantification part. WIth this version though it prints off several pages and is not very clear. What I am having to do is open up the sequence table in the offline copy then do a print screen and paste into Word then print from there and this is very annoying,---
Dear Pacerlaser.
I would like to know if you solved this problem, because I have the same one, eleven pages intead of one or two is very annoying.
many thanks.
I still have not solved this issue, but I'm continuing to work at it. Any ideas on your end?
