Autosampler and Headspace
We are currently making specifications of autosampler and headspace for GC 7890. Any recommendations? We plan to attach the GC to Waters Xevo QTof . GC and LC will be using one MS then. Im just concerned with the compatibility issues. Thanks
What compatibility issues are you worried about?We are currently making specifications of autosampler and headspace for GC 7890. Any recommendations? We plan to attach the GC to Waters Xevo QTof . GC and LC will be using one MS then. Im just concerned with the compatibility issues. Thanks
The APGC ion source is totally separate from the ESI source. While you can control the 7890 from MassLynx I don't know if you can control the Agilent G1888 or 7697A headspace Sampler... Not a big deal IMO as it's easy enough to start a run from the HS sampler...
That said I know the Combi-PAL (which can do liquid or HS injections) is supported in MassLynx...
BTW what do you plan to use the APGC source with the XEVO for?
- Karen
In total there are 26 users online :: 0 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 26 guests
