Run an Excel macro from Chemistation
Does anyone knows how to run an Excel macro from Chemstation.
I am going to run a macro named “mytest” in an Excel file. Below is my code. I tried RunExcelMacro() function and DDEExecute, both of them did not work. My Chemstation version is D.01.02. Does anyone knows what is the problem? Thanks.
local excel$,myPath$,myFile$,MyString$
excel$="C:\Program Files\Microsoft Office\Office\excel.exe "
myPath$="c:\temp\"
myFile$="test.xls"
excel$=excel$ + myPath$+ myFile$
a=exec(excel$,2)
chan = ddeinitiate("excel"+val$(a), myFile$)
! DDEExecute chan, [RUN("Mytest")]
print RunExcelMacro(chan, "Mytest")
DDETerminate Chan ! Close the channel
Remove excel$,myPath$,myFile$,MyString$
I presume that version D.01.02 is the Mass Spec version of the ChemStation. I am only familiar with the GC version of the ChemStation. In the GC version, you need to address the 'system' in Excel to send commands. I have the following commands in a macro to control Excel
chan2=DDEInitiate("excel","system")
ddeexecute chan2,"[WORKBOOK.ACTIVATE(""Page 1"")]"
ddeexecute chan2,"[PRINT]"
You can try this, but please not the use of the '[' brackets, they have to be there.
Gasman
Thanks for your help. I am using Mass Spec version Chemstation.
However, it still not working when i copied your code. It gave a DDE error:26 message. Here is the log file:
Log file is C:\MSDChem\1\log.log. Logging is on
ELSE
ENDIF
RETURN
macro "runexcel",g
TEST
myPath$="c:\temp\"
c:\temp\
myFile$="test.xls"
test.xls
C:\Program Files\Microsoft Office\Office\excel.exe c:\temp\test.xls
a=exec(excel$,2)
Executing: C:\Program Files\Microsoft Office\Office\excel.exe c:\temp\test.xls
Execution completed.
2168
2.81858e+009
9/13/2011 14:58:07
Macro: TEST, Cmd: ddeexecute chan2,"[WORKBOOK.ACTIVATE(""Page 1"")]"
Msg:
DDE error: 26
endlog
logging off
yorkflying,
I can not help you any further, as my experience is with GC ChemStation macros, and there is a big difference between the Mass Spec macro language and the GC macro language.
Gasman
Users browsing this forum: Bing [Bot] and 2 guests
