Calculation of average Velocity cm/s
Posted: Tue Sep 20, 2011 2:54 pm
Hi
I'm trying to calculate the Average Velocity of a gas... So far I've managed to work out the outlet flow based on the Poiseuille equation, an example of which can be found here:
http://www.sge.com/uploads/8e/ab/8eab97 ... 0025-C.pdf
I've got this to work without problem but have not managed to get the correct values for the average velocity cm/s
Does anyone have a formula to share with me?
P.S.
I'm actually after the 'inlet flow' shown in some software calculators (Agilent Column/Pressure flow calculator for example). I can get the outlet flow based on the Poiseuille formula. Does anyone know where the 'inlet flow' value comes from?
P.S.
