5890 II plus inlet temperature fluctuating
I had problem with the GC 5890 II plus, the inlet temperature is not stable, It is actuating by 5+/- from the set point, I did replace the heater/sensor assembly and also the main-board and also I did put more insulation in the inlet port with out any success. Do you guys have and idea about what is going on.
You need to provide more information:
Setpoint of injector
Oven temperature, including program profile
Thanks I got it fixed. It was the heater sensor assembly that i put new.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 5 guests
