6890 Clock Table
Can someone please advise on how to clear events stored in the clock table using the keypad interface? Running a 6890 with Waters Empower v.2. Thanks in advance!
Cheers,
Jeremy
You might need to disconnect it from Empower first (just pull out the cable from the GC). Go to the top status screen, press Delete, and I think it then asks what you want to delete. Press the Clock Table button. Are the same events not also seen in the Empower instrument method?
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 5 guests
