liquid chromatography
hello,
i'm trying to assay for active ibuprofen in tablets using hplc,which method can i use
The application data base of Macherey-Nagel has already done the work for you! Just go to:
https://www.mn-net.com/web/MN-WEB-appli ... PLC-117840
And your problem is solved.
for a further base of application look as well at the Merck de web site.
http://chrombook.merck.de/chrombook/index.jsp
both site together will give you about 6000 applications.
not all aplications can be found but many times if you don't find the specific cmpound you can get a good overview with a "cousin".
Users browsing this forum: Bing [Bot], Semrush [Bot] and 7 guests
