Ion exchange: step gradient peaks
Posted: Sun Oct 23, 2011 8:35 am
My ion exchange elution method increases my Buffer B (2M NaCl with 20 mM bis tris propane pH 6.
concentration in a stepwise fashion, 5% at a time (0%, 5%, 10%, 15%, 20% --> 100%).
At 10% and 15% I see distinct absorption peaks at UV 280 and 265 nm, even though I've only injected a blank buffer (bis tris propane 20 mM).
Also, I see distinct absorption peaks any time I jump to 100% B or back down to 0% B. Again, these peaks appear even when the system contains no sample, only buffer. Is the sudden change in salinity causing my peaks?
[ Column: GE HiTrap Q HP 1 ml anion exhange)
