Any cheap alternatives to HPLC?
Posted: Sun Oct 23, 2011 7:16 pm
Hi
I'm attempting to isolate C-type natriuretic peptide from chicken brains, which have a pretty high concentration at .5-1 pmol/g tissue weight.
I've found a patent which details the exact isolation method, however it requires the use of HPLC. While I have frequently used column and ion exchange chromatography in the past, I do not possess an HPLC machine and definitely cannot afford one (seeing as they go for 10,000+$ on LabX!).
Could anyone help me with a suitable alternative that is cheap (looking for under 100-200$). I have access to any column/ion exchange columns I need, not sure about gas. The purity doesn't have to be super high, but I would prefer it to be over 75%.
Here's the patent with the isolation method, hopefully there is a different way! The procedure is about 3/4 down the page.
http://www.freepatentsonline.com/5338830.html
And if you don't want to look through it all, it basically entails extracting the tissues with acetic acid et al., running it through an HPLC column, and then running an ion-exchange column to yield 3 fractions, the third of witch is the crude final product.
Do you think I could skip the HPLC step altogether? I am unsure if the HPLC is used to simply purify it further; remember, I don't need 99% purity, simply over 75% will do.
Thanks everyone!
Thanks everyone!
