Analysis of glucosamin HCl and Chondroitin Sulphate
Posted: Mon Oct 24, 2011 9:40 am
Hi all..I need your help..
Is it possible to analyze glucosamine HCl and Chondroitin SO4 in same column using UV detector?
I have tried it before using ODS Hypersil column, and the peaks look great..
But I have another problem..
--> When I injected glucosamine alone, There are two peaks..which one of them has similar retention time with the peak of Chondroitin SO4.
--> When I injected chondroitin alone, There are two peaks..which one of them has similar retention time with the peak of Glucosamine HCl.
Does the glucosamine contain some chondroitin and otherwise? If it so, is it possible to analyze them in a same column?
For your info, I use Methanol/ water as diluent and Acetonitrile / Phosphoric acid for the mobile phase..
Thank u ..
Thank u ..
