prepacked DEAE anion exchange column?
8 posts Page 1 of 1
I would appreciate any suggestion about where I can buy a reliable pre-packed DEAE anion exchange column for protein and DNA analysis. I need to use that in Perkin Elmer autosampler HPLC system so I have to be cautious about packing it by myself since I have not done that before.
Thankssss in advance
Zahra
Zahra:
PolyLC sells PolyWAX LP columns. While the functional group is not DEAE-, this material is still a weak anion-exchange (WAX) material, which is the relevant concern for your two applications. You should get a material with a pore diameter of either 1000- or 1500-Å (the 1500-Å material is particularly effective for PCR reaction product purification).
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
Thank you very much Andy. That was very useful.
Hi Zahra,
Here is a link of one DNA analysis we have done using our SAX(prepacked DEAE) column: http://www.sepax-tech.com/application_notes/PD1002.pdf; one newsletter on this topic as well: http://archive.constantcontact.com/fs00 ... 41547.html FYI
You can find more application on protein, peptide and Polysaccharides in the application tab here: http://www.sepax-tech.com/Proteomix.php
We also develop one good data using polymer based reverse phase column on DNA analysis, please feel free to contact me twu@sepax-tech.com if you are interested in.
Ting
Ting Wu:
A DEAE- functional group is a tertiary amine; it stands for "diethylaminoethyl-". A material with DEAE- groups is a weak anion-exchange material (WAX-type). Strong anion-exchange (SAX) materials have quaternary amine functional groups. The difference in performance (other than the more hydrophobic character of a SAX material) is that WAX materials lose their (+) charge in a continuum from pH 5 to pH 9.5, while SAX materials retain most of their charge as high as pH 10. Now, which kind of material does Sepax make?
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
Hi Zahra,
Ting
Thank you Ting that was very helpful comments.
Ting Wu:
Hi Andy, we both offer DEAE and QAE column and did research on DNA analysis on both columns. Sorry I did not mention that in the previous communication. Thanks for pointing this out. The WAX data here: http://www.sepax-tech.com/application_notes/PD1003.pdf
Hi Zahra,
Ting
Hi Zahra, Sorry I made a mistake: DEAE is WAX column. We have a data on WAX column as well: http://www.sepax-tech.com/application_notes/PD1003.pdf Sorry for the confusion. You may find this data in the newsletter I mentioned previously too. Hope you will find a good solution on your test. Happy Friday!
Ting
8 posts Page 1 of 1
Users browsing this forum: Google [Bot] and 20 guests
