Force ChemStation to move fraction collector to next vial?
I'm using an Agilent 1100 HPLC with a fraction collector. Is it possible to manually force ChemStation to move to the next fraction collection vial?
Hi
I assume you mean manually in the software rather than physically.
I dont remember seeing a command for this, all I believe you can do is by peak detection and time.
Yes, I was hoping there is a software command or "button" for "next tube", "next fraction", "split peak", etc. A physical solution would be ok too, but I expect that's less likely.
Users browsing this forum: Semrush [Bot] and 14 guests
