Ion exchange using DOWEX
Hi all, I am new to the forum. I am a student at the University of Vigo, Spain. I have a barium salt, with a lot of solubility problems, and impurities, I guess, that gave rise to a lot of weird peaks in the proton NMR spectrum, and so, I wanted to exchange the Barium cations with a DOWEX 50x8 acidic resin. The resin was in the lab for a long time, and nobody knows about a correct protocol to use it. It would be of great help if you could give me a hint on the matter, because I was told to just dissolve my molecule in the minimum amount of water possible, add the resin and stir the mixture, and then just filtrate it using a vacuum pump and I would therefore obtain my molecule in the protonated form. I tried this, but the proton spectrum of what was left when I evaporated the solvent, was not what I expected. I also have the possibility to use an Amberlite IRP-689-Ion exchange resin, which has sulfonic acid funcionality, in its sodium form, and I have a protocol to activate it to its acidic form. I also tried this, but when I eluted the column, I didn´t obtain my molecule neither...
Eduardo Troche
University of Vigo
contact your local BioRad distributor. BioRad has (or used to have) technical bulletins describing how to regenerate ion exchangers.
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 18 guests
