Uninstall ChemStation version A from computer
Posted: Sat Oct 29, 2011 9:38 am
by chemviren
I would like to uninstall ChemStation version A.10.02 from my computer but when I go to Control Panel -> Add/Remove Programs, there is no ChemStation program to uninstall.
Has anyone run into this problem and found out how to uninstall?
Re: Uninstall ChemStation version A from computer
Posted: Sat Oct 29, 2011 4:41 pm
by chemviren
also, it does not show up in the registry.
Posted: Sun Oct 30, 2011 2:55 pm
by dblux_
As far as I remember you only need to delete HPChem directory from your HDD.
PS
unnecessary remaining shortcuts may then be deleted from Start Menu and from Desktop.
Posted: Mon Oct 31, 2011 6:57 am
by chemviren
h
Posted: Wed Aug 26, 2015 10:20 am
by avh00
Sorry to bump this old thread, but I'm having the exact same problem.
When trying to install a more recent version, I get an error message stating something like 'Chemstation A.XX.XX is installed on this computer. Please uninstall the software and run this setup again.'
I have deleted the HPCHEM folder and all shortcuts I could find. Even scanned the registry for references to the software, but no luck.
Any ideas?
Posted: Wed Aug 26, 2015 10:34 am
by dblux_
[PCS] section in win.ini file - what if you delete it
HP*.ini files in Windows directory - will not be neccessary
Posted: Wed Aug 26, 2015 10:58 am
by avh00
Fantastic; that worked. Thanks!
Posted: Wed Aug 26, 2015 11:21 am
by dblux_
My pleasure
