low HPLC assay results
recently I did a HPLC assay for drug substance, the result is 95%w/w after correction of water and solvent.
As is result is about 90%, water is about 4.47%w/w and solvent is about 0. Ash is 0.38%w/w. impurity is about 0.7%w/w.
The calucation and precision are quite good. Just wonder what are the posible things for the rest of 5% in the material and normally how to identify them.
Thank you guys!
Thank you guys!
Did you include standard purity in the calculation?
Users browsing this forum: Bing [Bot], Semrush [Bot] and 5 guests
