Agilent OpenLab GC-FID query?
Posted: Fri Nov 25, 2011 5:02 pm
Hi Guys,
I am really stuck with my data analysis at the moment. I have run some samples containing poly aromatic hydrocarbons through a GC-FID. I want to get rid of the background compounds so my chromatograms look cleaner. Does anyone know how to delete unwanted peaks from the chromatogram? I have tried right clicking on the chromatogram in report mode and selecting properties. I then changed some of the settings to only give me a certain range of values and ran the sequence again but nothing changed! I hope this is making sense to someone and I can get some help because it is desperately needed! I would appreciate any advice you guys can give me because I am really stuck at the moment!
Cheers,
mrgb89
I should have mentioned I am using Agilent ObenLab software!
Cheers,
mrgb89
