ESCi mode for Xevo - few simple questions
Posted: Sat Nov 26, 2011 12:09 pm
Does anyone here have some knowledge and experience with ESCi mode for Xevo TQ?
I need to develop several methods and I know some of them are going to be using ESI while other - APCI. I am thinking about setting up my equipment for ESCi mode from the start (before development) instead of changing probe from APCI to ESI and back as required by applications, but I'm not sure about two things:
1. Is there no problem in running ESI while corona pin is installed? (I'm wondering about things like damage to the pin.)
2. Is there really no difference between APCI using proper probe and APCI in ESCi mode? After all APCI probe have heating element, while ESI (used in ESCi) does not.
Is there anything else I should know, consider, be aware of etc?
[edit - topic changed for clarity]
