peak alignment and quantification software
Hello. Are there any freely-available programs that compare LC-MS runs (high resolution (100,000)) in full scan mode without regard to the analyte(s) of interest?
Essentially, we would like to use this approach for several of the various "-omic" approaches as a way to identify differentially-expressed molecules in a complex mixture, and go back later for targeted MSn characterization from a specified mass list rather than performing quantification via a BIG5 or some other DDA approach.
Any thoughts would be appreciated. Thanks.
XCMS can perform peak detection, integration, re-alignment, etc. as well as a little bit of multivariate analysis. There is an online version that is very user-friendly. Worth a try.
https://xcmsonline.scripps.edu/
The "real" software version works under R environment.
and R is free and fairly easy to set up, and you don't need to know much about R in order to run xcms.
If you do decide to install R, it will also handle PCA for you (and if you're feeling clever it can do PLS too).
