Eudragit and ethyl cellulose - HPLC assay
Hi Folks
Have any of you worked on HPLC analysis (assay) of Eudragit LD30 (Methacrylic Acid - Ethyl Acrylate Copolymer (1 is to 1) Dispersion 30 per cent) and Ethyl Cellulose?
Take care
in polymers it is important to know the range of the expected sizes of your compounds.
are they water soluble or organic soluble?
You can do it with a SEC column, based on Polymer matrix, for water soluble compounds. A 50mmol/l acetate buffer pH5,8 I would use. Please google for more applications published on the www. Good luck.
In total there are 16 users online :: 2 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
