Can i determine the peak area by mannually calculating
Can i determine the peak area by mannually calculating the peak area? i have some old data with no peak area...can i calculate from the chromtogram? how do i do this? thank you
In the old days peak areas were determined by cutting out the peak from the printed chromatogram. The peaks were then weighed.
You can also approximate it by triangulation, but Mattias' suggestion is better.
maybe you can also use the peak height for your purpose?
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 22 guests
