How to Calculate the Accuracy of GC Analysis?
Dears,
Can any one help me in calculating the accuracy of an on-line Gas Chromatograph analysis when the accuracy (+- error) given by GC manufacturer is 1% of the range of measured component and 2% by Calbration Gas supplier.
Would it be calculated by formula as follows, (old time learned)
Analysis Accu= squar root of (1)2 + (2)2 = +-2.449
(Description: Squar root of GC accuracy square + Calibration Gas accuracy square)
Thank You
Athar
First of all, I think you are referring to precision, not accuracy.
And yes, the precision (relative standard deviation) is the square root of the sum of the squares of the independent contributions.
