Agilent Edit Sequence
So we had a power outage and edit sequence not longer works when using chemstation. I can load a sequence. I can run a sequence. However when I click edit, nothing happens. The edit screen does not pop up. Anybody have any thoughts on how to fix this issue?
Reinstall ChemStation. (run Setup from install CD/DVD, select Upgrade)
Agilent VEE is a graphical dataflow programming software development environment from Agilent Technologies for automated test, measurement, data analysis and reporting. VEE originally stood for Visual Engineering Environment and developed by HP designated as HP VEE; it has since been officially renamed to Agilent VEE. Agilent VEE has been widely used in various industries, serving the entire stage of a product lifecycle, from design, validation to manufacturing. It is optimized in instrument control and automation with test and measurement devices such as data acquisition instruments like digital voltmeters and oscilloscopes, and source devices like signal generators and programmable power supplies.
Users browsing this forum: Google [Bot] and 2 guests
