GC/MS
They can be used - but are not "nice" solvents for GC. Water has a high expansion volume in the GC inlet. DMSO and DMF have high enough boiling points they elute later in the chromatogram than many other commonly used solvents. In GC/MS water has a tendancy to hang around in the mass spectromters. If you look at the discussions on this site, you will see where water causes problems in purge and trap analysis.
I have an analytical method where we are using DMF as a solvent along with MSTFA. The chromatograpy works out just fine, but the analytes of interst are fairly high boiling.
We use DMF routinely, with trimethylsilyl derivatization.
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 18 guests
