Agilent 7694 Installation into Chemstation
Any guru's out there know how to install the Headspace Sampler to Chemstation? The error message is "cannot find chemstation". Chemstation is B.03.01 and the headspace is running A.01.06. I have them both installed on another machine that works fine but can't seem to connect with this configuration. Thanks for any help!!
Do you see the headspace info in your instrument menu when you open chemstation? there is a configuration page where you provide it with the headspace's IP address and everything communication wise. You may also have to hit the reconnect button to refresh the chemstation-headspace communication.
If you have the headspace and GC plugged into a hub you should try pinging the headspace and make sure you can communicate on that level before involving chemstation.
