Sacrficial Base (Ion Suppression)
Is it necessary to Use TEA when my buffer pH is 2.3 and my analytes are acidic in nature ?
In my case, the peak shape become good with TEA when compare to without TEA. But I didn't understand Mechanism of TEA in lower pH. Because silanols pKa is around 3.8 (so at pH 3.8, Silanols will be 50% ionised) and as we decrease the pH, ionisation of silanols will decrease. So i didn't see any strong reason to use TEA in my case though its giving me good peak shape :?: .
While pH is 2.3, is TEA bind with the Silanols :!: ?
What about using Trifluoroacetic acid? there can be any benefical effects in peak shape? I need the mechanism how they are going to act ?
TEA can act as an ion-pairing reagent, especially at that low a pH.
If the peak shape is better with TEA than without TEA, then it is necessary in your case! :wink:
In total there are 9 users online :: 4 registered, 0 hidden and 5 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot], Semrush [Bot] and 5 guests
