Injection Volume Control in Chemstation
Hello, I am running a sequence where I would like to inject different amounts of each sample (sample A - 1ul, B - 2ul, then C - 2.5ul, for example). This is an Agilent GC-MS with Enhanced ChemStation D.01.00.
In the method I can specify inj. vol. but this is a global control. In the "Sample Table Log" there is a column labelled Sample Amt. but according to ChemStation help this is not related to inj. vol. but to a normalization procedure for quantitative reports.
Any suggestions? Thanks in advance!
Luke
Sorry - I meant to post this in the GC-MS section, although I guess it also fits into this section. Feel free to move it if you think it would go better in the GC-MS forum.
I've looked at my Chemstation versions. The "old" version A10.3 gives you the possibility to override the injection volume, programmed in the method. The version of the GC/MS Chemstation I have does not have this possibility. I suugest to create several methods, all having the exact conditions, except for the sample volume. You can then build your sequence table accordinly.
Gilbert
Gilbert Staepels
Ideas mentioned in this note represent my own and not necesseraly those of the company I work for.
Gilbert - Ah, that is a good work around, thank you!
Luke
Users browsing this forum: Google [Bot] and 2 guests
