LC Method Development Time Limit
Posted: Thu Feb 16, 2012 12:25 pm
Honestly, how many working days do you accept as acceptable for analytical development of a LC method with five analytes, please?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
You mean there are times when that DOESN'T happen ???? Not in my world !!!Then there are the times you spend many weeks coming up with a method only to be told that they need to change the formulation and use different raw materials. That is always fun.
I guess you did not start with mixed-modewhy 5?
you can spend weeks only on 2 until you get them right.
just for example, we had a case of 14 compounds that we got a method in a day and validated in one week, in another case one compound and one "impurity", took us 15 columns to screen for it and we needed to go over temp. and pH as well. resolution 1.3 at best. about 4 month work on and off, waiting for some of the columns
My company deems much of such research as trade secret, doesn't like to go outside even if there's a confidentiality agreement, afraid such information will "get out" and tip our hand as to future plans. Believe me, I've inquired about that free method development support several times.Mixed-mode allows you to analyze a much wider range of compounds in terms of polarity and ionic properties. These are reasons why we offer free method development for our customers. Just tell your manager that somebody else can do it for free (or don't tell the manager and pretend that you did this work
Agree about the fragrances. More than once I would come up with a method only to have the fragrance changed. As I am sure you are aware, there are often a very large number of peaks seen in any one fragrance which must be separated from the active. At one presentation I had to make to one of the exalted ones in the company, I got some small colored beads from a crafts store and made up 0.03 % (w/w) white beads in black to show what this level really is. It amounted to four white beads in an 8 oz jar almost full of the black ones. I then made up another jar of 0.03 % white beads in a jar containing all the colors of beads of the same size I could find at the crafts store to show what it was really like trying to see a small amount of the active in a formulation containing a large number of separate chemical compunds from all the raw materials in it. For probably the only time I was at that company, they actually seemed to comprehend what I was saying!Historically, we have found that the biggest potential interference is from fragrance. For one API, at one time there were at least 30 fragrances used in the various products containing that API, so the API had to be resolved from components in all of them !!!
This is a nice comparison, but I am not sure that it is a correct one. In your experiment bids are only different in color. In chromatography analytes are different by several parameters (hydrophobicity, polarity, ionic properties, etc). The correct experiment would be to mix colored bids with other shaped colored objects. So even in your case you can separate them by shape and color using simple mesh (after you separate them by color) or just spreading them on a flat surface. Chromatography is science of selectivity.Agree about the fragrances. More than once I would come up with a method only to have the fragrance changed. As I am sure you are aware, there are often a very large number of peaks seen in any one fragrance which must be separated from the active. At one presentation I had to make to one of the exalted ones in the company, I got some small colored beads from a crafts store and made up 0.03 % (w/w) white beads in black to show what this level really is. It amounted to four white beads in an 8 oz jar almost full of the black ones. I then made up another jar of 0.03 % white beads in a jar containing all the colors of beads of the same size I could find at the crafts store to show what it was really like trying to see a small amount of the active in a formulation containing a large number of separate chemical compunds from all the raw materials in it. For probably the only time I was at that company, they actually seemed to comprehend what I was saying!Historically, we have found that the biggest potential interference is from fragrance. For one API, at one time there were at least 30 fragrances used in the various products containing that API, so the API had to be resolved from components in all of them !!!
