Dionex P680 HPLC Pump can't run, Thanks
Posted: Fri Feb 17, 2012 3:09 am
Dionex P680 HPLC Pump would not run.
When I set up prime or flow rate, the pump stops.
It shows: Drive Current too Larse. Camshaft 157 degree or
Excessive drive current. Camshaft 160 degree
Then it stop run.
i have let it rest one day, then it also has the problem when i try to use it.
Then it stop run.
