print empower 2
Dear all,
since a couple of weeks i'm working on a project to get my GC working on Empower 2.
at this moment everything is working well, ik can callibrate the system and all my samplesets and results can be processed with good results.
but the problem starts when i select the print option while processing.
for example when i have injected 10 samples and i want to print the results empower will print reports 1 then 1+2 then 1+2+3 etc.
i think this is not very good for the enviroment, and my bosses wallet :P
i have no idea why it is doing that, because all the results have been processed once.
can anyone help me??
greetings,
Paul
Don't print until after you've finished processing the entire run.
DR
Thanks DR
so you mean i should only print the resultset or results.
gr,
P
In total there are 27 users online :: 2 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 25 guests
