Standby.mac dissappered
Posted: Wed Feb 29, 2012 4:17 pm
by Ludique
GC does not go in standby mode anymore, since it starts up below room temp, LN2 consumption is through the roof.
GC 7890 DHA6729 application by AC
Chemstation B04.02 SP1
Post sequence box checked, Macro "standby.mac", go.
We cannot find standby.mac anywhere on the C drive, is it hidden or is it the reason why GC does not go in standy mode post sequence?...
Where can I get this standby.mac file and must I adapt it to fit my application?
Re: Standby.mac dissappered
Posted: Thu Mar 01, 2012 12:04 am
by Steve Reimer
Have you tried running a dummy method as the last line in your sequence? One that is always above ambient or with no cryo so your LN2 isn't running.
Posted: Thu Mar 01, 2012 2:00 pm
by GasMan
The macro file should be in the CORE directory of the ChemStation, i.e. C:\Chem32\Core. If it is not there, I would think that AC probably supplied a CD with the macro on it. If you do not have this macro, you should contact AC.
Gasman
