What role does Sodium Dedecyl Sulfate play in Mobile Phase
What role does Sodium Dedecyl Sulfate (SDS) play in Mobile Phase? I have a test method where SDS is added to acidified Methanol: Water (2:1). I would like to understand if SDS affects the retention time of HPLC Analysis using the above mentioned mobile phase? If it does, how?
Thanks in advance for any comments.
SDS acts as an ion-pair reagent.
Do a search of the Forum using "ion pair" as the keywords and you will get a tremendous amount of information about the topic. Chris Pohl had a very informative post a few weeks ago (maybe a bit advanced for your question, though):
http://www.sepsci.com/chromforum/viewto ... t=ion+pair
Hi Tom,
Thanks for the tips. I will certainly do a search using your suggestion.
Charissa
Users browsing this forum: Google [Bot] and 12 guests
