Agilent Cerity A02.02 - Signal to noise calculations
Does anyone know how to enable this calculation ?
For Gc system.
Here is what was done:
- we enabled signal to noise in the method
- we added the field in single injection and multiple injection screens
- we added the field to the report
however the value still displays N/A.
In one view it displays corresponding values but we cannot extract or print it. (sample 1 to Sample n)
The ASTM Mean and STD Dev Noise display's N/A
I'm guessing we need to define the noise in the system suitability the question is how do i do this?
Or define the noise somehow? Can someone help me ? Thanks
Hello dear collegues.
I have the same problem. I set up equipment to calculate signal to noise, but it does not. I have an idea why it does not. Just not sure. My system can not perform sequences. It only works in single injection mode. Can this be the answer? That that option is just not awailable? ChemStation version is A.09.03
Thank you.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 7 guests
