Changing tungsten lamps in perkin elmer series 200 DAD
Any tips?
Do you need UV safety specs?
1) the lamp should be off when you go to change it, so I'd not worry about UV specs.
2) Make sure the lamp's bulb is very clean and that you leave no fingerprints on it.
3) Find your detector's specs for sample and/or reference energy and make sure that they are met (and that this represents an improvement over readings from the old lamp) after the new lamp is installed.
DR
Thanks, but this is a perkin elmer series 200 DAD using total crap, I mean total chrom. I dont think there is anywhere to check lamp strenght. Unless someone can enlighten me?
In total there are 20 users online :: 2 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 18 guests
