Changing tungsten lamps in perkin elmer series 200 DAD
Posted: Fri Mar 23, 2012 10:06 am
Any tips?
Do you need UV safety specs?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
1) the lamp should be off when you go to change it, so I'd not worry about UV specs.
2) Make sure the lamp's bulb is very clean and that you leave no fingerprints on it.
3) Find your detector's specs for sample and/or reference energy and make sure that they are met (and that this represents an improvement over readings from the old lamp) after the new lamp is installed.
