Exporting in EZchrom Workstation for batch reprocessing
Hi all,
I am using EZChrom Elite workstation and was wondering if anyone ever successfully exported a sequence of data to go onto ONE Excel spreadsheet not multiples. Each time the data is reprocessed I get multiple sheets not one. I combined them into one manually by copying and pasting and someone also told me that each sheet can be merged into one Excel file as multiple sheets within the file. Any ideas? I have not tried Agilent yet but wanted to know if someone had experienced this previously.
Steve
Hello Stev,
as i'm using Openlab CDS for my customer for a specific solution, i will give you my experience, maybe it could help you. My customer need results from GC and upload it to their Lims. All results are coming from Ascii report files (option configured in Advanced Method). Those report are made by advanced report template which the editor is nearly similar to a Excel sheet. The idea is to make a small user program which collect data from a set of ascii report file and make a single file compatible with Excel (maybe a csv file for example). This is very easy to do, just need to know a programmation langage. If you have this possibility, it should be the solution.
Hope it help
Henri
Laboratory informatic support
SRA Instruments - France
