HILIC separations - can they be modelled by DryLab?
.... or is the separation mechanism too complex to understand or does not follow a strict linear solvation energy relationship?
Also, is it possible to perform gradient separations with HILIC?
To take those in reverse order:
Yes, gradients can be used in HILIC. Phenomenex has a good example on page 14 of their Luna HILIC brochure:
http://tinyurl.com/7mcwy5n
Re DryLab, HILIC is essentially normal-phase liquid-liquid partition chromatography. The "normal phase" mode of DryLab should do OK for that. If you want to play with it, the DryLab 2000 versions had a "custom mode" capability that would let you pick your own fitting function (I'm ot sure if that carried over into the later versions, though).
In total there are 17 users online :: 2 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
