is it common to use SCD detector re-calibrate everyday?
Dear all,
just start to use this photometric detector :D
sulfur chemiluminescent detector,
SIEVERS model 55 with dual plasma controller and burner hooked on Shimadzu GC2010.
the base line seems always hard to get stable, and the peaks shape changes, I need to re-calibrate everyday, which cost me a lot of GMIS standard, which is expensive. :shock: :roll:
is there anyone having the same experience or you may find some ways to prohibited the baseline change.
let me know
thank you
h
