Ask about the ASCII data of GC Perkin Elmer Clarus 500
Hello everybody,
Good day !
I'm using the GC Clarus 500 of Perkin Elmer.
I would like to ask the way to convert the raw data to ASCII file ( csv, txt ...) ?
For example : I run sample for 20 minutes. I want to obtain data as text file as follows :
Time(minutes) Intensity
0 100
0.1 120
0.2 150
0.3 ....
0.4
0.5
20
The more points, the better.
Thanks in advance !
You've proabably got this sorted by now, in case you haven't here is a pointer.
In Report Format Editor, from the menu bar select options, you will find ASCII under the misc. options section.
Iain
