Empower Reports
Hey, does anyone know if there is a field I can add to the report to show the filepath to the raw data? And where I could find it? I'm not having any luck...it's still pretty early though...
Eg./ C://Windows/program files/blah blah blah.data
Raw data is usually hidden, by design.
Your Empower admin. should be able to provide a path statement to it (raw file storage folders) if you're interested, but I can pretty well assure you that the files are going to be inaccessible by any direct means and pretty meaningless on their own.
DR
Ok, I was just trying to provide a trace back to the raw data for tracking purposes. Date and time acquired will suffice. :)
If you make sure that specific result set names & project names are included in headers, it should all be easy to trace. There are also numbers for pretty much everything that can be included and are specific to each project (injection ID, result ID, result set ID, sample set ID and so on).
DR
You can add your project information to your report (under special information), there you will find your path to the raw data.
Your raw data name of your chrom is equal to injection or channel ID, I'm not sure about this.
But as DR states: with project names as a header and result_ID mentioned, everything should be easy traceable.
Ace
