Column Selection....
I currently use an Agilent HP-ULTRA 2 to quantify Polyethylene Glycol in Carbowax.
I'm working on a method that will look at quantifying Propylene Glycol in a HydroGel. I've been getting good results from the PoraPLOT-Q column.
To avoid disturbing the system routinely, I was wondering if there is a suitable column I could use for both tests?
Regards.
IF
you can use the Agilent HP-ULTRA 2 for the propylene glycol
then you have the single column you desire.
I doubt there is any other possibility.
best wishes,
IF
best wishes,
Initial trials showed that the HP-ULTRA 2 didn't work with the PEG.
Based on that and what you say; it looks like we have no choice.
Thank you.
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
