AKTA Detector Lamp
I'm currently using an AKTA machine running Unicorn 5.11. One of my colleagues recently noticed through the maintenance module of the software that the detector lamp had been on virtually full-time since the unit was initially installed several years ago. She thought that she recalled in another AKTA/Unicorn configuration that there was a way for the software to automatically turn the lamp off following a run. I can find no such instruction in the software manual or on-line help. Any advice would be appreciated
you could find the akta supporting! or update the software.
Lisure science(suzhou)co.,Ltd
caixin
CAIXIN
Flash Chromatography Made in CHINA
www.lisurescience.com
Thanks for the ideas. I've found a way to turn the lamp off manually using the front panel control/menu, but if that gets tedious I'll probably investigate a software upgrade.
or buy a professional system - not least CDS :wink:
